Design or modify a radio...wishlist thread.
I have that same radio sitting in storage.
It is one of the" I can't pass it up and I am going to fix it some day " radios.
You know, one of those projects.
mine might have parts yours needs
Do away with ALL export junk. So much poor designing in exports.... from noisy RX, to overheated output/PA sections, to bad IF mixing stages, there just isn't anything good about them. Get rid of them entirely.
For CB's, go back to leaded solder so they are more reliable in a mobile, less prone to failed solder joints. Re-design the clarifier circuits for increased stability. Want a blueprint for all this? Go back to the late 1970's and early 1980's. Far better QC, better TX and RX, and far better frequency stability.
Wishful thinking, though.
~Cheers~
You are obviously a radio operator with good taste and will not tolerate junk in your radio room.
Reactions: Slowmover and Rwb
