The Ameritron or MFJ model 75MV is a good power supply to run a Texas Star 500v .
You can run the TS500V with up to 15 VDC if you like. all will be okay.
These are mobil amps designed to operate in a system that the alternators will output up to 15VDC. Not an issue.
I have operated my 500's at 14.3~14.5 volts for years with no problems.
