Ya the ASC doesn't work well at all on my linc.
Interesting how the Euro model has a PL antenna connector on the battery eliminator but on the US version you have to mess with the BNC on the top.
Here is some FM Randy action I found on the youtubes
For what the little rigs are, they are pretty impressive imo. First time I've seen the add on lapel mic, that sure makes it easy for the quick trip in a spare truck. Let us know how it does with a real antenna system.
I mirror your thoughts on the difference with antenna connection. Sure seems like the euro version is a better suit for using an external antenna.
Yes Shadetree Mechanic, I feel the same. I have yet to own an AM only radio as all mine are SSB. Even if you are a big AM user it's always good to have the SSB option!I wish it had side band. I will probably get one to take to the beach. Maybe rig up a 9 foot beach umbrella.Interested in your opinion on it.
73.
No argument as everybody needs a portable as well! I guess it’s the same reason as to why I don’t have a real base station and use mobiles instead(if I have to “grab and go” it’s a lot easier to stash and carry 3 148’s than 1 cobra 2000). You have a good point when you say not being tied to a vehicle or building (main advantage of portables). I guess the only disadvantage of any portable, in most cases, would be antenna performance(but that is the “nature of the beast”). In any case it’s always better to just have one (yes, or multipleNot meaning to be argumentative, but the Randy advantage is that one is not tied to vehicle or building.
— The Randy is pretty well always the second radio of a given radio system. Where another radio already exists in use.
— The Randy is both adjunct and backup.
When Randy is fly’n drive primary, how effective is another radio on SSB with short mobile antenna?
Exactly, what is one giving up? As mobile performance SSB may be no big deal anyway?
Good point. I don’t know if they make a SSB portable. However just like many things in life you can’t have it all! (have to give something up). I was just pointing out the fact that all my mobiles were SSB. What about a small mobile and carrying it like they do in the military?If there is a truly portable CB handheld with SSB . . is RX any good? What of TX?
IOW, the objection to a portable not being SSB-capable may not be relevant.
Since you mentioned it, do you own a McKinley? If so, are you happy with it? Good reports? Reliable unit? It is available in my area (he orders straight from President). It seems to be the only CB that is widely available and easy to get ASAP compared to other rigs that are discontinued, not available, or difficult to order.I used the Randy a short time in the KW. RX & TX both seemed fine. Had it been swapped for a UNIDEN 880 it would have seemed comparable given a handheld versus a mobile. (The Randy has some better features).
The optional mic had good reports.
A lapel speaker/mic and carrying the radio on a belt clip seems an obvious use. Work VOX into that. (Or — maybe? — lower 12V draw with earpiece).
This radio will be going to my son. A good fly & drive (which he does and I don’t), or as the campsite radio with dipole in trees, the McKinley in the car as main unit.
Imagination set loose.
I’ll let him figure solar re-charge, etc.
At $140 this unit seems a no-brainer to get the most from other radios owned (family & neighborhood comms, first) plus, easy portability for travel.
73.
