I don't think the Anytone or amp have a dedicated ground connector so I assume I just loosen a chassis screw and insert an eyelet connecting to the ground wire in this case. The PSU does have a ground connection as does the antenna tuner.Start off with something like this:
1.5 x7" C-110 Copper Busbar Power Distribution Bus Bar Terminal Block | eBay
Find many great new & used options and get the best deals for 1.5 x7" C-110 Copper Busbar Power Distribution Bus Bar Terminal Block at the best online prices at eBay! Free shipping for many products!www.ebay.com
and ground all of your equipment to it. Then use a large single conductor (copper strap/wide braid) and run it to an outside 8' ground rod using as short a run as possible.
What type/gauge of wire is recommended to connect individual devices like the Q5N2 chassis, amp chassis, SWR meter chassis, antenna tuner (if/when used) to the copper bus bar? I can see heavier gauge copper wire being a bit of a challenge to use.
