sorry i even asked the question. didn't intend to derail this thread so badly.
Nothing to be sorry about. You did nothing wrong. It is all good in my books. Someone else decided to make it a big deal.sorry i even asked the question. didn't intend to derail this thread so badly.![]()
It seems you really like microwave popcorn!A bag of popcorn is in the microwave......
J
500They will custom lable if you buy in bulk, something like 200 units.
Anyone got 75 Grand laying around to create the WWDX Model 1?
I need someone to send me a qt40 for teating. Im north of the border and some testing is needed.I was sent a QT-60, that I received today. It is for testing (evalualtion) and a review I plan to post in this forum.
I use my AT-5555Nii (QT-60) on 10m and 12m HAM mostly. And I personally find moving in 5kHz steps the BEST way to quickly scan an entire band in SSB mode, without missing anything. I also have a TS-990s and a FTDX10, both set to 5kHz on the course step. Both of these radio's are not expanded or modified - they are HAM only.sorry i even asked the question. didn't intend to derail this thread so badly.![]()
thanks. no, i have not. the manual says...did you work out the 5kHz step menu that you originally asked about?
OK, set Menu 13 (FR-CH) to FREQ.thanks. no, i have not. the manual says...
Function 6 'Frequency Step' "Note this function is only valid when the channel switch is defined as FREQ."
pressing the FREQ button, and the display showing frequency. pressing up or down on the Mic changes the Channel, not the frequency. pressing the channel dial makes one digit flash. then pressing up or down changes one integer at a time even though 5K Step selected in the menu.
am i doing it wrong? i dunno![]()
Good stuff!@Pez thank you! that did the trick.
annoyingly though it still changes the frequency of the Channel you are on even in Frequency mode (via Menu). while it's nice to be able to program channels without a PC, i wish there were a way to prevent accidental changing of channel frequencies.
thanks again Pez! this will make things much easier for me.
/max
A big Hell yeah from me too!Good stuff!
Yes, with all Qixiang radios you need to make a choice about what mode to run in... Either CH or FREQ (VFO). And then, you really need to stick with it (or be very diligent) or else the programmed CH frequencies will end up changed when you VFO tune off somewhere else.
FWIW, I never use CH mode.
Also, there is a very good chance that in the near future, Qixiang radios and new firmwares will fix this "issue". (I can't wait to see this happen). It was originally done this way on purpose, but the reality is that it doesn't help 99% of users.
The new method is designed so that if you VFO tune away from a programmed CH, this will only be temporary... So, when you come back to your CH 38, (27.385 LSB) after using VFO mode to move to 24.950 USB, the radio will return the originally programmed CH 38 (27.385 LSB). It won't overwrite it with the last frequency you went to in VFO mode, which is the problem now.
Can I get a "hell yeah"!!?? hihi
