Wawasee JB-2000 issues
no telling how your amp is different than that schematic,
and the amp here in town that I worked on.
(I never want to work on it again!)
but off of the negative side of the HV capacitor board,
a 10 ohm 10W going to ground. It acts as a little "cushion"
when powering up, and also can blow as a fuse.
any resistor around that value will work.
or is not needed.
but if your negative side goes directly to ground,
then maybe you have a burned open wire or trace
someplace on the capacitor board...
or bad rectifiers. transformer.
don't get shocked!
on them other amps the resistor is in this place. and plate current
can be measured more easily and safely, since it is in a low voltage spot.
Screenshot_20251203_212738_Gallery.jpgScreenshot_20251203_212642_Gallery.jpgScreenshot_20251203_212623_Gallery.jpg
Reactions: Naysayer
or is not needed.
don't get shocked!
I know one thing Bayyouradio, when I got this unit all 4 diodes closest to the driver board were all blown so I replaced all 8 with 5408 diodes and figured then I had already found my problem, WRONG unfortunately
Reactions: Naysayer
or is not needed.
don't get shocked!
Also, all I have on the front of my amplifier is what's on this photo, other models were different I think, the one you worked on might have have 4 knobs Screenshot_20251203_221116_Gallery.jpg
The HV filter caps all look original. Can't make out date codes printed on any of them, but I'm pretty sure that brand "Industrial" has been gone for 40-plus years.
That was a picture of them before the replacement Nomad here is what went in Screenshot_20251204_011345_Gallery.jpg
Reactions: Naysayer
I do now currently have this amplifier operating, I am not for sure what I did to get it functional I do not know if the tubes were gassy and that's why it was arching in them before or not. I burned them in for like a week with just the heaters on first, then added 1300 Volts to the plate and no arching occurred " I used half the PS like they do the driver " and I turned the amp on every night for a few hours for about a week like this. Then I did add the 10 watt 2 ohm resistor that is like a soft start on the power supply section as my amp didn't previously have one and it appeared like it never did have one. Then I applied all 2700 vdc plate voltage to the 3-500z tubes and no more arching! For now I have the driver bypassed and used Nomads keying circuit and am driving it with a JB 200 modulator off a Tram and seeing around 1000 watts of average swing on a MFJ meter. I had ran the amp for a few evenings and it appears to run very well however last night it started popping the breaker on the back of the unit however right now I am thinking that breaker may just be weak as I hear no other sounds or smells in the amp so far and I reset the breaker and it take off just fine again for awhile, it even trips if I just use my trams power as the driving unit not even using the modulator so I know its not tripping because its being overdriven. So far so good anyways so happy to have gotten somewhere with it ! Thank you very much everyone for your assistance and advice!
The series filament connection lets you use wire half as thick on the cathode choke. Also shrinks the wire size needed to wind the filament secondary on the power transformer.
Just be sure to put a fan of some sort just below the tube sockets. Doesn't have to be big, only needs a breeze not a hurricane. The wire that powered the driver tube's heater can feed a half-wave rectifier feeding into a 1000 uf filter cap. This will power a small 12-Volt DC fan. We drill two holes in the lip of the rail that runs under the chassis from side to side. A small fan only needs two mount holes to be stable. A 24-Volt DC fan running from 12 Volts
Kinda like this:
Adding cathode bias with a zener helps keep the heat down, but you'll want to install a tuned-input matching circuit if you do. It's barely visible in this image. I have pics of that, but not on the server I can access from home. I'll track that down next time I get to work.
Kinda like this:
Yes, sir I did add a small AC fan down there in that location already as I have heard and read about the pins solder getting to hot at times. I did not add any bias or any input tune at this time but am very interested in it if it will make this box run better and or more efficient. My input swr is currently 2.0 I didn't think that was bad enough to mess with the tune. Not really sure what the biasing board that you have used does or the purpose of it ? Keeps the 3-500z biased with negative voltage and keeps them under control more and cooler ? How much power loss is noticed? Or is the bias only present on standby unkeyed ? Thanks
