Or transformer I really meanProbably but hopefully not in my PS
no telling how your amp is different than that schematic,
and the amp here in town that I worked on.
(I never want to work on it again!)
but off of the negative side of the HV capacitor board,
a 10 ohm 10W going to ground. It acts as a little "cushion"
when powering up, and also can blow as a fuse.
any resistor around that value will work.
or is not needed.
but if your negative side goes directly to ground,
then maybe you have a burned open wire or trace
someplace on the capacitor board...
or bad rectifiers. transformer.
don't get shocked!
on them other amps the resistor is in this place. and plate current
can be measured more easily and safely, since it is in a low voltage spot.
I know one thing Bayyouradio, when I got this unit all 4 diodes closest to the driver board were all blown so I replaced all 8 with 5408 diodes and figured then I had already found my problem, WRONG unfortunatelyno telling how your amp is different than that schematic,
or is not needed.
don't get shocked!
Also, all I have on the front of my amplifier is what's on this photo, other models were different I think, the one you worked on might have have 4 knobsno telling how your amp is different than that schematic,
or is not needed.
don't get shocked!
cb amplifiers can never be cheap enough.
Yes I believe so, and not sure whyI just realized looking at the cathode are they running these on series at 10v? I wonder why they chose to do that
Yes, sir I did add a small AC fan down there in that location already as I have heard and read about the pins solder getting to hot at times. I did not add any bias or any input tune at this time but am very interested in it if it will make this box run better and or more efficient. My input swr is currently 2.0 I didn't think that was bad enough to mess with the tune. Not really sure what the biasing board that you have used does or the purpose of it ? Keeps the 3-500z biased with negative voltage and keeps them under control more and cooler ? How much power loss is noticed? Or is the bias only present on standby unkeyed ? ThanksThe series filament connection lets you use wire half as thick on the cathode choke. Also shrinks the wire size needed to wind the filament secondary on the power transformer.
Just be sure to put a fan of some sort just below the tube sockets. Doesn't have to be big, only needs a breeze not a hurricane. The wire that powered the driver tube's heater can feed a half-wave rectifier feeding into a 1000 uf filter cap. This will power a small 12-Volt DC fan. We drill two holes in the lip of the rail that runs under the chassis from side to side. A small fan only needs two mount holes to be stable. A 24-Volt DC fan running from 12 Volts
Kinda like this:
Adding cathode bias with a zener helps keep the heat down, but you'll want to install a tuned-input matching circuit if you do. It's barely visible in this image. I have pics of that, but not on the server I can access from home. I'll track that down next time I get to work.
