BinaryRock
Wasn't planning on another update, but I learned something new today. Sharing for those about to go down this road.
There are two different kinds of rotary encoders lol. Quadrature where both wires get a pulse regardless of direction (just timed differently), and the old ones like the old cobra radios used for the channel dial where each direction gets its own switch and only one sends in each direction.
The ones I foolishly ordered were the latter type (and delayed in the mail, of course) so I tried the cobra ch dial encoder today. It didn't work with my code. But now, it does. I added another switch in the firmware to select the encoder style so both can now be used.
And for some good news. I now have too much user config data to store it in userrow so my only choice is to leave the chip unlocked. If I lock them, the fun stuff would not be able to be changed and I'm not gonna be that asshole.
The first few are done but still missing buffer transistors and therefore haven't washed them. The faster transistors should arrive tomorrow and I hope to have some for sale by next week assuming I don't find any more bugs. These here already have a home lined up but I will make more next weekend.View attachment 77792
I gotta say, that black pcb and board layout is slick.
Reactions: brandon7861
@SuperLid
I connected a rubidium standard to the SA reference input and connected the reference output to the front input hoping that the rubidium source had a better phase noise than the SA in hopes to get an idea what the phase noise of the SA is.
I got this, 85.85dB down at +100Hz offset with RBW at 1Hz:
I then programmed the 5351 to output 10MHz and measured that. Since I did not calibrate the frequency yet, I simply offset the second marker by the same 100Hz and ran the averaging again. This time it showed 88.43dB. Somehow it is better than the rubidium source even though the rubidium was still being used as the reference.
Not sure how to interpret that, but if I adjust the voltage on the binaryrock board, the carrier peak and the second marker (and the entire noise floor) move in sync.
I don't know if the phase noise of the SA is limiting the measurement, but I am going to call this good enough. I did notice that the SMA on the rubidium was a tad loose when I took it all apart though, so maybe that should have been tightened better.
I have been wrapped up in antennas and other things lately. I would like to contribute to this, but I don't have the bandwidth yet. I have an Agilent SA here, in addition to several others. But my 2 Aeroflex CSM's are down now. I have a couple of Rigol's, but I don't like them that much. They are probably on par with that Siglent you have there.
Keep posting and I'll read when I can comprehend lol.
SL
I could make a slim version for xtal replacement only, but the firmware doesn't need to be changed to use it that way. It is easier to upload the same sketch and just change a few options at the top since I need to program them, let them run for a half hour, then reprogram them with the calibration data anyhow (now the slowest part of the process). The edge connector makes programming these a breeze though.
There will be hardware options too. You can select XTAL or TCXO, and for an AM only radio, the xtal is plenty. I also not populate the buffer parts if you want the 5351's output directly, kinda nice if you want to use the software power settings. And that brings up the hardest question.
Next task is to have the user configurables in the eeprom in a way that lets me provide the user the capability to update that info from terminal without having the user dig into the entire code.
I highly recommend NOT using xtal. The few experiments I have performed with the 5351's, the TCXO became mandatory for stability. The 5351's I have, came populated with xtal. So, I got some TCXO's that will replace them.
The buffered output is going to have to wait for the redesign. I made the pads and traces too small to handle the power dissipation. Too much transistor and load capacitance led to horrible gain above 20MHz and I cannot drop the drain resistor to compensate without things getting hot.
I don't think the majority of people will need the buffered output anyhow. I'll fix it on the next version.
Reactions: Cable Guy
Had a thought. When in fox mode, the clarifier span pads on the back did nothing, so I added another mode. If pads 29 and 30 are grounded, it becomes an alarm transmitter that sends a short message (19 characters) when PF0 is brought low. It can also append GPS data to the transmission like GPS mode does.
Now we can connect motion sensors to it too. Complete instructions coming soon.
I added all the features to the website. It has instructions for all the modes. It also has instructions for firmware settings, the necessary files, and info on how to calibrate the TCXO. I'm sure I will be updating things here and there, but the basics are now covered. I have now finished testing all the modes that it has.
And just when i update the site and call it a night, i think of one final mode to add. Factory dial mode. I will add the option to use all 7 pin inputs as a binary input that has a customizable channel table. 128 possible channels. Should be able to sidestep any factory rom pll with its own dial hahaha. Edit: tried today, not enough user eeprom left, so setting this table will require programming the entire sketch.
Reactions: TM86
Decided. I will be putting the entire ino sketch on the website tonight after I test the new factory dial mode. No more userrow or eeprom to complicate things.
If someone does clone it, at least there will be no doubt who did the binary thing first. More importantly, if someone else goes down this road, they can hand AI this code and AI can use it as a guide for building theirs (like the variable speed thing)
Kinda have my mind blown. I suspect that anyone who has ever tapped on a crystal while measuring oscillator frequency knows that it sometimes makes them move, sometimes a lot. I have been engraving the PPB calibration on the back of these boards as I set them and I finally gave up double checking after engraving. None have changed from the vibration. My counter only goes to a tenth of a Hz at 10MHz, but engraving them doesn't move it and I thought that was cool.
What I can say with certainty is that no-clean flux WILL affect the calibration of these TCXOs. The PPB correction factors are smaller after cleaning the boards.
I measured the regulator temperature at different voltages. At 9.2v, the regulator is about 135F. Connecting it to 13.8v brings it up to 190F (in the open air) which is on the hot side. I recommend using the radios 8-9v regulator as a power source, not the 13v supply line. added: The current draw is 30mA.
Shouldn't overburden the 8 or 9-Volt regulator in modern radios. An older radio that uses just a zener diode and ballast resistor will need to have that resistor removed and a 7808 or 7809 regulator put in its place. Or simply adding a regulator just to power the BR would be less trouble. The smaller 78L08 TO-92 version is probably big enough without having to make room for a TO-220 package.
Shouldn't overburden the 8 or 9-Volt regulator in modern radios. An older radio that uses just a zener diode and ballast resistor will need to have that resistor removed and a 7808 or 7809 regulator put in its place. Or simply adding a regulator just to power the BR would be less trouble. The smaller TO-92 version is probably big enough without having to make room for a TO-220 package.
Even a few series diodes would probably suffice on 13.8v just to drop it a little.
If I make a new version, the copper will be upgraded for the regulator too. Another noob mistake, learning as I go.
When I was running it on 13.8v and 190 degrees F, holding my finger to it briefly dropped it to 165F. It shouldn't take much copper to make it tolerate 13.8v. I was even thinking of finding a little quarter inch wide copper or aluminum clip to put on the regulator that wraps around the board.
Reactions: nomadradio
I will pull out the reflow preheater and see if I can test them at 150 degrees at 9v.
In the process of calibrating 10 more boards now.
Update: the preheater wouldn't go low enough so I had to improvise. Results coming soon
Results: At a board temp of 140F, the LDO is at the recommended maximum operating temperature of 185F. I think we are going to be ok inside a tube radio. Maybe mount it low and away from the tubes somewhere just to be safe,
