Anytone at-5555n II (version 2)
Yeah I turned down both volume and time factor for echo to 01 and seems to be about right and not so processed sounding and a little touch of echo and or reverb is fine though.
Reactions: jdchet
When I bought the v1 5555n the seller put a sticker on the box with software links. That sure made it all really simple.
The Amazon seller was luckyproduct, not sure which seller everyone else has been buying from.
Reactions: TIN_CAN
Its basically tuning under the hood so to speak, you can customize your freq along with many more things very easy to use, just need a data cable for your radio download software and install on windows pc
Yes unpacked just fine in windows 7 and opens up but cannot read from radio..says cannot read com port....no I am using an AT-6666 cable? mabey thats the problem.
mine works on port 3 but I am using cable for that radio not from 6666. Not sure if anyone else in here is running this software with other cables.
Reactions: TIN_CAN
Thank you sir, going to try on my desktop which does run windows 10 and have connected my 6666 with success . If not try another cable.
Cheers!
When I asked about that cable, the seller specified one for the NII listed in their store. The also had one listed for the quad 6 so I was thinking they were just blowing smoke to make us buy another. Maybe the cable really is specific to this radio.
Reactions: TIN_CAN
  • @ Hambones amps:
