BinaryRock
I've been playing with the TCXO calibration of these boards. The vast majority of the correction factors are between -150PPB and -350PPB. I calibrated these boards earlier today when the wood stove was going and the boards were at 83F.
Now, the boards are 70°F and I am checking them again at 10MHz. I am seeing, on average, 30PPB difference. I have to subtract about 30PPB to bring them back to 10.000 000 0. The boards are about 0.2Hz to 0.3Hz higher at 70°F from when I calibrated them at 83°F.
The datasheet shows an operating temp range of -40°C to 85°C and a 0.5PPM across that range. That's 4PPB per °C if I interpret that correctly. 83°F - 70°F is 13°F, and that's a difference of 7.2°C. 7.2°C * 4PPB = 28.8 PPB. The temperature drift I am measuring seems to be spot on with the specs.
All this is to say, don't bother chasing that last tenth of a Hz if you calibrate.
SuperLid gave me an idea for a new walkie talkie mode.
In this mode, there are 4 pins that individually choose one of 4 channels, and those channels are determined by soldering channel numbers to the solder pads as chunks of 6-bit binary for each channel. The software looks up the frequency for that channel and subtracts 455kHz from it. When PTT is brought low (or high, has a switch), it adds the 455kHz back to it. So now you can pick any 4 standard channels, control them from the factory channel switch, and it does the 455kHz shift automatically. All other modes remain the same.
To use this mode, you would feed the oscillator the same signal and reroute the channel selector wires to operate the channel pins instead of having those switches selecting crystals.
Updating the sketch and website instructions tonight to reflect these changes. I will try to make a full video demonstrating each mode and its options this weekend so people don't have to read the instructions.
I added a new rotary encoder mode. This one is like the other rotary encoder mode, but it sacrifices the band switch function to add a PTT input. Now we have an RIT function. In this mode, the clarifier span is fixed at 5kHz up and down and a long press enters TX adjust. After 3 seconds idle, it goes back to RX adjust. A short press in either mode centers the frequency to the soldered value as before.
Went a little further. A short 2 second press enters TX adjust, idle for 3 seconds goes back to RX mode. A 5 second press locks the two together, and an 8 second press makes them independent again.
Edit: and i removed the time output when using GPS (no need for it) and turned it into an amp-keying line. Now, when it sends its pulses and identity, it can key an amp before the clock comes on and releases it after the clock goes off with customizable delays. I also turned off PLLB since it is not in use. Im up to rev6 and I have three empty mode switch combinations still available.
I have another pretty cool idea.
What if one of the boot modes completely repurposed the frequency input pads and instead were used to select pre-programmed use-cases like the 11.125MHz in the uniden washington.
Until this point, almost all my inputs have been active low. This washington use-case uses active-high from the mode switch (and also controls the clarifier). Nobody wants to invert that to use my board. Look up the radio, then the crystal, select that mode from a chart, and simply wire as instructed. No thinking involved.
Now the real work begins.
I think you will be keeping me busy this winter.
Reactions: brandon7861
I decided I had better try one of these in a radio so I am in the process of replacing all of the synthesis crystals in my uniden washington with these boards. Why stop at one, right?
So far I have the 10.24 swapped out and the 11.1125 swapped out. I still need to yank the 7.8MHz crystals and add one last board, but things are going very well so far and I am excited!
I will make a short video explaining what I did for each of the three boards once I have the last one installed.
I have so many reasons to redesign this board now (multi-clock, copper pour, bigger regulator, input level shifting, a screen, wireless app, MAR4+ on the output idk...) but that's going to have to be a winter project.
I have a question, is this 455kHz filter still being designed by someone? Is this product still in production use?
I have all the crystals in my washington replaced with the boards. Seems to work great, talked to a local on it for a while. One issue, with the addition of the last board, I now seem to have some tones on certain channels. Drive already set to minimum. I will have to poke around and see what is causing that.
Back at work for a few days, but I wanted to comment about this birdie/tone issue because this is going to be a common issue for all of these Si5351 clock boards.
Before I put the last board in, the radio worked and sounded great. After installing the third board, the radio still worked good, talked on AM,LSB and USB. The only issue is that a few of the channels have a tone in SSB and LSB has a slightly higher noise level on the meter. I removed the feedback capacitor from both the 11MHz and 7MHz oscillators, and that did help some, but the problem did not go away.
The PLL can take a square wave, it's built for that, and the 11MHz oscillator is followed up by a tripler (tuned transformer) that cleans up the signal, so that probably explains why the first two caused no issues.
The third board is for 7.8MHz, and looking at the schematic, there is no tank/tuned circuit between this oscillator and the balanced modulator and mixer. It relies solely on the oscillators waveform being sinusoidal. Using the SA, I am able to see the offending signals coming from this oscillator.
I will be thinking of a way to add a tank to this circuit in the next couple days. There are a few ways to approach this, and I may try a couple different things over the next couple of mornings.
The point of this post is to make it clear to anyone wanting to install a board like this that not all circuits tolerate a square wave. This is not a drop-in solution where the radio has no tuned circuits! And this is the difference between the Si5351 clock chip and DDS chips. Too often people call these 5351 clock chips DDS, they are not! DDS will digitally create an approximation of a sine wave, clock chips output square waves.
