Compressor
brandon7861
Loose Wire
I Support WorldwideDX.com!
Nov 28, 2018
2,366
2,614
293
I never studied compressors, but I saw this video and thought it would be fun to try. I only had single op-amps but the plans call for two duals and a quad. Slapped some uv mask on the traces, still don't know why i do that, just makes it a mess. I still need to get the pots and a metal enclosure.
This is going to be one of the two boards for my home brew desk mic. I have no idea how well this will work for voice but I thought it would be worth a try.
I have built several different style compressor/processors, even sold some to locals that used quad op amps back when I was at school (long time back),
I have built them using discrete transistors & vogad IC's too,
Imho RF type clippers that operate on the principles seen on pa0fri.com out perform any audio based clipper/limiter type speech processor,
They can sound thin if the filter you use is narrow or you use a sharp crystal filter but they give your low power radio a BIG readability boost in a pileup.
  • @ Catalyst 122:
