Electronics Experimenter's Idea. You Got The Smarts?
Wire Weasel
Senior Moment
Dec 13, 2008
3,308
970
223
I had an idea a few years ago and briefly tried to put one together to see if would work - it didn't - and I didn't feel like keep playing with it regarding time, research and money although the money was little.
Small (up-sizable) Solar Panel LED Perpetual Light:
I don't think my idea violates any laws of electrical physics ..... just a matter of finding the right components.
The idea is to determine the best small solar panel ( A & V output), rig up whatever number of whatever type and size of white LEDs to shine directly onto the panel. Although the LEDs will be shining onto the panel there will still be enough outwardly reflecting light to illuminate the surrounding area some. Get the rig going by shining a bright flashlight on the panel to power the LEDs - remove the flashlight and the LEDs power the setup from there.
Present day components may not be available to accomplish this ?? What is required is (enough) LEDs to power the panel while not exceeding the panel's output capacity.
Still won't work. The amount of power needed to light the LEDs is more than a panel can make for the surface area an LED can illuminate.
Reactions: BC Coyote
As Enine said, it still won't work. Perpetual energy is a myth.....you can't get something from nothing. Basic physics gets in the way! :)
Yes, what everyone else said but, to put it into layman's terms, a solar panel cell is only about 15-22% efficient in full sun while converting light to usable electricity. This is even before figuring circuit loss. Perhaps this will help some. You project is never going to work but, experimentation is always fun and normally your learn something with it even if its an unexpected negative result.
Reactions: Captain Kilowatt
