    Dismiss Notice
Dismiss Notice
Spectrum analyzer
Discussion in 'CB and Export Equipment and Accessories' started by kaos513, Jul 2, 2020.
  1. kaos513
    kaos513 Sr. Member
    Apr 10, 2014
    2,341
    699
    Anyone know of an affordable spectrum analyzer
  2. sp5it
    sp5it Master of puppets
    Jul 9, 2009
    1,879
    2,058
    Range, budget?
  3. kaos513
    kaos513 Sr. Member
    Apr 10, 2014
    2,341
    699
    Maybe between 300 max
  4. kaos513
    kaos513 Sr. Member
    Apr 10, 2014
    2,341
    699
    I need advice on getting one eBay saw some decent used ones
  5. kaos513
    kaos513 Sr. Member
    Apr 10, 2014
    2,341
    699
    I have an sdr but don’t know how Accurate will it work to align a radio
  6. Tallman
    Tallman W9WDX Amateur Radio Member, KW4YJ EXTRA class
    May 1, 2013
    5,123
    5,913
    I would not even begin to align a radio using another radio. The only way to go is to use Laboratory grade equipment and it has been calibrated by a company that is NBS traceable.
  7. kaos513
    kaos513 Sr. Member
    Apr 10, 2014
    2,341
    699
    Yeah I’m looking
  8. nomadradio
    nomadradio Analog Retentive
    Apr 3, 2005
    4,698
    6,209
    Receiver alignment calls for a signal generator. The cheapest ones do not have a calibrated output level or output frequency. The ones that do have that used to all be expensive, but I expect the chinese to change that sooner or later. A spectrum analyzer that uses only a USB connection, and has no built-in display or controls tends to be cheaper. You use a laptop or such as the controls and display.
    A spectrum analyzer is typically used to observe and measure the output from a transmitter. In particular it will show how the transmitter's output power is spread across a range of radio frequencies. A transmitter is more effective when its power is concentrared mainly on the selected channel, and not spread across the band. The fancier types will let you measure the exact output frequency of a transmitter. The simpler ones won't.
    Tokin, Woody-202, Robalo and 4 others like this.
  9. Slowmover
    Slowmover Elmer
    Feb 17, 2015
    5,105
    7,936
    Means you’ll have to drive it to New Mexico.
  10. Robalo
    Robalo Well-Known Member
    Aug 21, 2006
    541
    189
    for 54 MHZ tune. I use white and black tv on channel two mobil tv it works. L36 on cobra 148 gtl lol (y)
  11. DTB Radio
    DTB Radio Well-Known Member
    Sep 14, 2005
    1,014
    66
    Rigol is about the cheapest lab-grade brand I've found. I use a DSA815, found on Ebay for about $700. Anything you find for $300 (or even $400), will likely be 40+ years old, or not of the grade you need. That said, you can get some good deals on older HP mainframe analyzers if you look and be patient.
    Tokin likes this.
  12. OldTech03
    OldTech03 Sr. Member
    Dec 15, 2017
    678
    1,153
    Well, I don't know where the $700 DSA815'S Rigols are Hidding but I'm sure you can find one with patience. I purchased one with all the trimmings and it ended up being closer to $3000. I'm not unhappy with the Rigol at all but getting one without a Tracking Gen isn't a waste of money but it does take away from its effectiveness but if you feel no need for that part of the spectrum then a much cheaper version is all you would need. Check out the Avcoms or any that look like them with different names some even have the Tracking gen in them for as little as $300 I have seen them. I sold one here some months back with the TG for 350.
  13. Tallman
    May 1, 2013
    5,123
    5,913
  14. Low_Boy
    Low_Boy Sr. Member
    Jan 21, 2010
    1,666
    967
    I have the basic Rigol with out tracking generator. I do not know what they cost now I paid someplace mid to upper $600.00 range. It does what I need it to do and a lot more..
Share This Page
  • About Us
    The WorldwideDX Radio Forum was originally established in 2001. We pride ourselves on welcoming Radio Hobby enthusiasts of all types, while offering unbiased, informative, and friendly discussion among the members. We are working every day to make sure our community is the best Radio Hobbyist's site.
  • Like us on Facebook
  • Premium VIP Member
    The management works very hard to make sure the community is running the best software, best designs, and all the other bells and whistles. Care to buy us a beer? We'd really appreciate it!
    Donate to us!
