uniden washington
Glad to know it worked - wanted to know if there were other issues that could have been addressed.
Found a few but if it works, no need to fix it "more better" - :)
Reactions: S&W357
I'd also look into cleaning it a second time. They don't ALWAYS get clean the first time, especially if they are excessively dirty.
Is there any excessive shaft wobble on that pot? Had the same problem with the center wiper in the pot that wasn't making a good connection with the resistive oxide surface due to shaft wobble. Ended up having to replace that pot. Hope you don't have the same issue. Clean it well.
