What was your last meal??
We made mini phillies on toasted kings hawaiian buns tonight and they were surprisingly good!
A serloin was cut into 1/4" wide x 1/8" thick x 1" long strips so that the thinnest cut was across the grain and that was spread out on a plate and lightly sprinkled kosher salt and coarse pepper and let it sit for 2 hours (on the counter as it was still very cold). White onion, mushroom and bell pepper were also sliced in a miniature manner and set aside. The peppers were squeezed of excess moisture as they were frozen and had to thaw after cutting. In a cast iron pan, equal parts (enough for buns) butter and grapeseed oil (because I wanted to try that, no real reason) were pre-heated in a cast iron pan and turned off.
To a wok was added a decent shot or more of avocado oil and heated on medium heat. In go the mushrooms and onions as they take the longest. You may need a grease screen! Once the onions soften up and you think they could start browning any moment, toss in the meat and mix around. Keeping things evenly spaced, crank it up to high and try to drive off the moisture that accumulates by moving the wok around, but dont stir/flip meat until most of the water evaporates. Give it a flip/stir and wait a minute. Just as the last sign of red is about gone, toss the bell peppers on top and wait a minute. By now, most of the water that came out of everything has evaporated and you can give it a final stir and minute to sear the meat and turn it off. Cover with sliced provolone and cover to melt. Crank up the cast iron pan and drop the buns in as soon as the butter starts bubbling. The rest is easy to figure out. It sounds like the meat is in the pan for a long time, but there ends up being a lot of water.
  • @ Catalyst 122:
