Who Makes The Most Durable Coil Tuning Tools?
DTB Radio
Sep 14, 2005
1,116
228
Carlisle, PA. USA
www.dtbradio.com
For thirty+ years I've tried to find coil adjustment tools for everything from miniature coils in certain RCI models (even smaller) up to the larger coils found in some very vintage ham gear and CB's. The ones I have the most problems with are the ones found in a typical Cobra 29 LTD or Galaxy DX radio 933, 44, etc). I buy fresh tools, only to have them break within weeks, sometimes days. I end up whittling them down to the proper dimension, which lasts again for days or weeks, only to repeat the process. I sometimes have luck melting the tips and forming them into the coil, but that often leaves overshoot material which must be whittled back anyway. As a backup, I worked a small sliver of aluminum down to fit in those cans and glued it to an old plastic tuning stick that was broken. With care this works ok, but because there is still some interaction magnetically, it takes some additional tweaking. I understand the risk of damaging a slug, but I am careful enough that that doesn't happen. At any rate, the question to my fellow professional technicians who frequent this board is, what is your preferred brand/model of tuning tools for this application? Durability is by far the top priority.
Reactions: doffo
Well having done all the things you just talked about I to have never found a set that lasts for very long, Now I do use the ceramic tuning tools and they last for ever but present the same issue that metal does with respect to inadvertently breaking cores if you not careful. I do find myself taking time out to reform the tools that I have and after 53 years of doing this I have hundreds. I don't have any thing I have found that is really significantly better than the list below. The biggest problem in a long lasting tuning tool will always be the core breakage issue. If I had foreseen the issue I would have purchased a few hundred sets when they were 1.95 a set instead of the 14.95 they currently are now. It's kind of odd that I was fixing some of them on the bench when I stumbled on to the post.
Knowles Voltronics
GC Electronics
Philmore Anti-Static
Unfortunately it’s kinda like asking for a fuse that will never blow. Just can’t get the protection of a soft tool with the durability of a steel tool.
If I did a lot of tuning, I’d look into 3d printing them. I’d bet the right filament with maybe even a good annealing would last a decent while for the little cost. Petg or maybe nylon?
Reactions: Cable Guy
I'm using celluloid guitar picks for tip material and polymorph for the handles.
Back in the bad old days we used a G-C tool called the 9440. Had the 1.5 mm flat tip that was a perfect fit to the 10mm and 7mm Toko coil slugs. Just one problem. The red plastic tip would snap right off if the slug was too stiff. Upside is that it was too soft to fracture a seized or stiff slug. Started using ceramic tools from fleabay, but you have the opposite challenge with them. Way too easy to fracture a brittle slug with a tool tip that hard.
Learned to use a light touch. And to remove a slug with a damaged slot, flip it over and screw it back into the hole with the undamaged end exposed.
Reactions: doffo
Thank you all for your replies and thoughts! I knew I couldn't be the only one facing that dilemma, lol! Interesting idea on the guitar picks, never thought of that! I usually carry about half a dozen guitar picks or so in my wallet in case I get a chance to play when out and about, but I think these, being Fender mediums, might be a bit light. I'm definitely going to give one a try, though! Thank you all again for the thoughts!
You can also buy celluloid sheets of any thickness. Celluloid (guitar picks) are made of nitrocellulose and campor (flammable) so be careful with large amounts of it.
