Who Makes The Most Durable Coil Tuning Tools?
DTB Radio
Well-Known Member
Sep 14, 2005
1,112
226
Carlisle, PA. USA
www.dtbradio.com
For thirty+ years I've tried to find coil adjustment tools for everything from miniature coils in certain RCI models (even smaller) up to the larger coils found in some very vintage ham gear and CB's. The ones I have the most problems with are the ones found in a typical Cobra 29 LTD or Galaxy DX radio 933, 44, etc). I buy fresh tools, only to have them break within weeks, sometimes days. I end up whittling them down to the proper dimension, which lasts again for days or weeks, only to repeat the process. I sometimes have luck melting the tips and forming them into the coil, but that often leaves overshoot material which must be whittled back anyway. As a backup, I worked a small sliver of aluminum down to fit in those cans and glued it to an old plastic tuning stick that was broken. With care this works ok, but because there is still some interaction magnetically, it takes some additional tweaking. I understand the risk of damaging a slug, but I am careful enough that that doesn't happen. At any rate, the question to my fellow professional technicians who frequent this board is, what is your preferred brand/model of tuning tools for this application? Durability is by far the top priority.
Reactions: doffo
Well having done all the things you just talked about I to have never found a set that lasts for very long, Now I do use the ceramic tuning tools and they last for ever but present the same issue that metal does with respect to inadvertently breaking cores if you not careful. I do find myself taking time out to reform the tools that I have and after 53 years of doing this I have hundreds. I don't have any thing I have found that is really significantly better than the list below. The biggest problem in a long lasting tuning tool will always be the core breakage issue. If I had foreseen the issue I would have purchased a few hundred sets when they were 1.95 a set instead of the 14.95 they currently are now. It's kind of odd that I was fixing some of them on the bench when I stumbled on to the post.
Knowles Voltronics
GC Electronics
Philmore Anti-Static
