New profile posts
Your 422 amp: Did you notice a reduction in current for 422's compared with 2879's?
That was why I went to 28v w/ Palomar 900HD. When amp new, it wanted more current than my 40A PSU had. I have no measurements but PSU no longer strains. What are you using for 28v PS?
Neil NYC
SuperLid
SuperLid
Ohm's law does apply here. I have not used this amp in almost 30 years, however I still have it and plan to make some changes and use it. The current plan, is 6 MeanWell 28V 6.5A SMPS's in parallel. The old plan was 4 parallel Glenayre 26V 14A SMPS, removed from paging transmitters.
I need to know whether the Yaesu FT990 can easily be hooked up to an acom 1010 amplifier. What is the proceedure?
Tin Can, Alabama Buckeye here. PowerMax PM4-100 V PM3-100? I've a PM3-75 which does not have neither switch nor voltage set screw. Is that the same on your PM3-100?
TIN_CAN
TIN_CAN
Hey Alabama Buckeye, I just went to radio room to confirm, both PM3-100 and PM4-100 have voltage adjustment 13v-16.5v and switch that selects 3stage and fixed output. Hop that helps you out, I run both in tandem at 14.5v to run all my amps and radios. fans have come on once since I have owned them.
Alabama Buckeye
Alabama Buckeye
I'm interested to know why 14.5V?
I adjust my 200A power supply to 14.5V. Stryker 655 or 955 either will readout 13.7V draw. I presume a protection component in the werx
Might I guesstimate 14.5V for the benefit of greater watt output from linear amps? What boost might that be, 80W?
QTH#1:Realistic TRC-490 w/Turner Super Sidekick driving Starduster clone or IMAX 2000; QTH#2:TRC-465 w/Johnson desk mic driving A99; Marine Mobile: Cherokee AH-100 w/t driving Shakespeare 5223
Lately this new guy Rob AKA Skybanger has been making a lot of waves. He's made a lot of people mad.
Where is Tim Hoffman and Eric Oyen N7ZZT?
Reactions: techradioman
T
techradioman
I don't know whatever happened to either one of them, they've been gone a long time. Are you on the radio (11meters)here in Phoenix ? If so what is you name or numbers. I'm Tom 2915 in North Phoenix
357
357
Tim is on there right now sqealin....nothing more than squealin...
