Yeticom Optima 10/11/12 Meter Export Radio reviewed @ cbradiomagazine.com
  • Start date Start date
I've had my Optima for just over a week now in my pick up. All reports say clean clear audio on AM and SSB. I like it, its going to be a keeper in my truck.
My experience also, I had a local yesterday swear I was at home on my base, he was about 25 miles away, I was about 2 blocks from my house. Yes I have it in my Chevy Tahoe with a large roof and a wilson 5000 exactly in the middle so I get a good ground plane and yes I did tune it so it is at it's lowest on the upper side of the 11 meter band but it is only a radio doing 50 watts not a power house amp working off a base antenna. I love mine, so much I bought another for a back up or for the base. I do have an antenna on the garage too but for some reason that place is a lightning catcher, had 2 hits in 2 years so no expensive radio in there, they all get fried
ebay special
received my Ebay special Yesterday.Seller lied !It's a early mark 1 with the 6 pin mic{Cry_river} .Still a good radio though, think Ill keep it.frequency is rock solid. Pa stays cool as a cucumber at 50 watts. Rx is very good, gives my ft-100d a run for it's money. SSb Tx Audio could do with a little more drive, but gets good audio reports.Fm sounds good. Anybody know how to tweak the ALC.When I sell the Last 3 radios , that I bought over from the states, I might order a mk2.
Optima Mk1
You may find the mic has a pot inside of it. Play with that first. All pots inside the radio are marked on the board. Take a photo first so you can return things to status quo if you twist the wrong thing!
quite often... if something is too good to be true .....
I haven't seen what output power is on lowest setting for AM and SSB. Wondering if TS-350HD will handle lowest output of this radio.
All pots marked except two, one would be bias the other I guess is alc.Think I will leave them alone until I can borrow a scope.Improved the audio by removing the fibre washer in front of the mic insert drilled a larger hole in it and then replaced it.Now I need a good AB biased high drive amp.
pots...
nnnnnooo
Inside the mic. if you have an early 6 pin plug optima it may have a pot in the mic case. Just like magnum delta force, S-45 and 257 etc.
If it is 8 pin socket then it will not have the adjustable pot in the mic.
rgds,
Dave
Drool....
I just read all of the some 27+ pages of replies of this thread and really really want a MK2 now :drool:. I run an HR2510 both in the mobile and the base and was wondering how the MK2 and the 2510 compare. The MK2 would be installed in my SUV most likely. I love the small size of the MK2 and its features. Just need to save the $$ and pull the trigger.
So HR 2510 VS Optima MKII?? Any thoughts? Or how about an RCI 2950DX VS the MKII?
^^ ab v c^^
Thanks!
Greg
^^ ab v c^^
Thanks!
Greg
The 2510 and the 2950 both have "channel banks", the Optima does not. The Optima tunes just like a real HF rig - continuously. Otherwise, the features are similar. Also the 2510 doesn't have repeater splits but the 2600 does, (unless you've Chipswitched it, and then you need an encyclopedia to use it :rolleyes: :confused1:).
BlackPaw I have one in the box only taken out to check output and audio on SSB. 375 shipped USA only and I'll throw in a HM-36 mic as I have like 4 of them right now.
Replaced my 2950 with the Optima today. My DD is an 2000 Cherokee Sport. I have it mounted between the visors and still use the Wilson 1000 roof mount.
I noticed my fuel pump whine is moderately reduced, but I miss the speaker on the 2950. I need to make some local contacts to see how the Icom HM-36 mic compares to the little stock mic.
At least, so far, I got a little power boost.
My current setup, hm-36, optima mk2, dx500, tentec 1225 meter, wilson 5000 hardmounted. I've talked a lot on 10 meters as well as 38lsb. I'm not running it hard, about 375-400 and get great reports everytime I talk to someone. I'm finding that for audio wise, most think I'm running some big fancy HF rig and an expensive mic.
