Homemade Sigma 4 11 meter base antenna
I know nothing about the different software engines you note, so there could be a notable difference, but I doubt the difference is as much as you suggest. Do you have specific information that talks about this subject?
I have done something similar in an article where Cebik produced enough modeling details to try and duplicate his work. I only had to figure out close to the height he used and the number of segments...and I got so close I was amazed. I don't know which Eznec he used however.
Could you post a link to that Cebik article you used?
Hopefully the link works, I can't access it from work:
Backyard wire antennas
no eddie i got it from cebik, the arrl open sleeve article, and reading about transmission-lines, we talked in emails about where i thought transmission-line and antenna mode currents were flowing in the open sleeve sigma astroplane and in gamma sections well before shockwave obtained the cst plot,
my opinion of how it likely operates has not changed since a week or so after i last corresponded with cebik, im pretty sure you know that,
cst does not show what im trying to show,
the first one was for the extended version,
i tried to show the same thing first time around not well so i did another one for the 3/4wave, i remember you pulling me over about the same thing in my other drawings, i have not changed those either even though you were right, ezbob gui needs some work with sign of phase,
i still missed at least one current on this one, i hope i got them in the correct relative phase.
If the currents inside the 'cone' are equal and opposite of those outside the 'cone', what determines it's phase so that they 'cancel'?
Phase is determined by the length of the vertical radiator. Anything longer than 1/2 wave will cause phase inversion at the base over the exact length this radiator extends past 1/2 wave. In the case of the Sigma, that's 1/4 wavelength. Remember, this is an unbalanced antenna with CMC flowing on the cone. Cancellation requires equal and opposite currents and that is not what we have in the Sigma.
Dam! Sounds remarkably like a 'J'-pole, doesn't it??
Depends on where you begin listening to the discussion and at what point you jump out.
The J-pole is simply a 1/2 wave monopole with a very large 1/4 wave matching stub.
The Sigma differentiates itself by having a Gamma Match for impedance matching instead of what is arguably the largest matching network relative to antenna size out there, and a 1/4 wave lower cage that contains phase inversion within it while producing in-phase currents on the outside of the cage/cone that contributes to the at-the-horizon RF radiation.
The J-pole is a 1/2 wave monopole.
The V4k is a 3/4, or longer, end fed monopole based on the iteration employed without the out-of-phase lower end currents characteristic of other end fed monopole antennas that exceed 1/2 wavelength long.
As far as additional gain is concerned, that would be simply the function of the additional overall length of the V4k if nothing else. Perhaps it is simply that there is more of what matters down there where folks live - on the horizon.
Whether one chooses to accept the CST plot or not is the privilege of the individual. I have seen similar resistance to Eznec modeling, and Ezbob modeling on this forum no matter the antennas in question.
Good questions are being asked, and I am watching to see if the answers supplied awaken any additional understanding in my middle-aged brain.
What I do accept is my personal experience with this antenna.
Something accounts for the improved performance of theV4k over other antennas set to both the same bottom and top heights. We look to technological data, ie science, for explanations, yet resist the available explanations when they coincide with the experiences of those who've gone the additional step of mounting the antenna and proving the data empirically.
What I have learned along the way with many other things is if someone dislikes a thing and your experience supports their predisposition, you are right, however, when your experience does not support the predisposition of others, then you are wrong.
I have had some tell me the 6' radials on the A99 were the cat's meow. When I added them they provided absolutely no detectable difference for me. I don't see them as anything more than an unnecessary expense. On the other hand, I believe all verticals benefit from a good GP system. Now, whichever way you see it I have either just been affirmed, or disallowed as ignorant.
So, in fairness, I promise that if you agree with me I'll like you when you say something I agree with. . . :biggrin:
Shoot. That was said in so many fewer words . . .
i very strongly suspect that if someone swaps a J-pole for a vector that they will easily learn that they are not so similar .
I think I've seen a CST pattern for a 5/8 wave antenna and I believe it was for a Sirio antenna. Does anyone have such a link?
I think Shockwave would be the only one that might have such pattern views.
    boog351 has left the room.
