Tak-tenna Antenna systems
I tried to make one 3-4 yrs ago. Never tuned up. I probably didn't know how to count turns and curl wire into spirals like some of the real antenna spinners. . .
It looks kind of like a scaled-down version of what I used to build for tractor trailers and I'm assuming that since it's mounted up so high it would probably be fairly comparable. With all the room a base application offers, It would be hard to justify scaling something down that small.
If you have limited space then it's not a bad antenna to try. It does take some tuning! It will never be as good as a full sized antenna, but, it's certainly better than nothing.
Ditto the 'round-toit' thingy...
Reactions: HomerBB and binrat
Well, I have made an antenna out of a folding aluminum chair frame too.
They don't even know the difference between minimum VSWR and RESONANCE.
"The RF frequency is applied across the band to locate the SWR minimum frequency; the two wires ends - having alligator clips - are moved 2 inches at a time on each spiral to bring that SWR minimum to the frequency of your choice.
When your achive resonance, the clips are removed and..."
I also liked the "HOT" and "COLD" RF sides of a dipole concept, isn't RF AC.
YMMV
Reactions: Captain Kilowatt
This method works fine for maintaining efficiency to a point, but for a 40 meter antenna a 30 inch boom is just to much shortening, the same with their 48 inch boom on the 80 meter antenna. Sure they will function, and if you have nothing else that will fit they are better than that alternative, but to be effective they are simply way to short.
Their site is also riddled with errors. For example from their FAQ page...
A resonated antenna is a metal object having a GEOMETRY such that it CREATES a PURE 50 ohm RESISTIVE load at the end of the transmission line.
Anyone who know anything about antennas knows this is false, resonance is completely different to anything that has anything to do with any concept of "resistance", and the "resistive load" at resonance can literally be any amount of resistance that is possible and depends on the antenna itself.
All this antenna really is is an antenna with a funny looking top loading coil that doubles as a kind of capacity hat as well. Such methods are fine to about 40% of the antenna's overall length before the efficiency (from ARRL Antenna Book series, older books), however, as I pointed about above, the boom lengths used are well shorter than that.
The DB
Reactions: rabbiporkchop
Went to this site and read a review, okay guys what do you think? Let's rip this apart or give it credit. Basicallly is it a sham or what?
Evidently a lot of people are happy with these as there are 146 reviews on eHam with an overall rating of 4.5 out of 5.
I know some people discount eHam reviews (except when pushing a product they care about) but I suspect eHam reviewers represent a good cross-section of radio enthusuasts just as this site does. Reading their reviews is no different than asking a question in any of these forums. You are going to get all kinds of answers. But once you sift through them all you can likely make a somewhat informed decision.
Get one, HM and let us know how well it works.(y)
