I can't remember what size I used. Water pipe is measured by inside diameter, I believe. Your best bet would be to take the hub with you to see what fits. I do remember cutting the threaded portion off the pipe so the hub screws could get a good bite on the straight part of the pipe.Now I have to find the right size pipe to fit the hub...of the antenna..
