Eldorado828
UDX-828 in the Lonestar state (WDX-828)
Thank you for going out of your way, very appreciated.
In this application with the low drive available, radios do better with the MRF455 or believe it or not, the real Toshiba 2SC2879. Both of these parts have a gain of 13db while the 2SC2290 comes in at 11.8. The original final these boards were trying to replace was the extinct MRF477 and it had a gain of 15db.Looks like you could drop one of these in let's say a galaxy 33hp2, general lee, or connex 3300 and essentially have a connex 4300. I'm curious to see how it'll do with a real Toshiba 2290! The parts values look to be the same as the one available in the connex 4300.View attachment 40602 View attachment 40601 View attachment 40600
Found that trick out when they came out with the MRF492A. It's got one more db than the 1446 and that single hole mount was convenient on the back of radios that didn't work the part hard enough to overheat it.Should rock and roll with a SD1446, a 50 MHz part used at 27. Plenty of gain.
Be sure to let us know how it turns out.Well I snatched up a few, we'll see what happens...
Chop, Have you had a chance to play with those boards yet?Well I snatched up a few, we'll see what happens...
