UR6QW EQ'S
I bought the other one. Sold by the same guy on e bay. From Ukraine. It was less money. I hated it No way to monitor your sound. I was told my radio sounded better with out it. I ended up sending it back.
The switch isn't for echo the fast/slow switch is for attack time on the Noise Gate. Echo is controlled with delay and amount knobs.
Front jack isn't for headphones - it's a mic input jack. I have radios with VOX so I can plug in my headset mic cable into there and earphones RX into the radio and then I can talk using a boom mike headset and run my audio through the ur6qw.
Very cool for hands free operation! :)
I really need to READ MORE... (y)
Lol, reading helped some if you can get past the broken english hahaha.
Im getting great audio reports and no more ac and fans blowing in the background.
Just made couple to see how it worked in a mobile radio, 10 band eq, SP1A, peak limiter and echo. All bypassed by jumpers but UR6QW EQ is straight off the datasheets, his echo is also straight off some datasheets. Waiting on some parts to assemble.
Reactions: Slowmover
I have the 10 band model with digital display. Really great sound for the money. Ran various mics through it into modified cobra 29 and stryker 955 (caps fattened up for wider transmit audio) with great results.
I’m going to be testing the digital model shortly. Going to try dynamic and condenser mics via the XLR as well. Should be interesting.
Can you record the audio similar to your W2IHY 8 Band review, where the receive radio was near the bench.
