I bought the other one. Sold by the same guy on e bay. From Ukraine. It was less money. I hated it No way to monitor your sound. I was told my radio sounded better with out it. I ended up sending it back.
I really need to READ MORE...The switch isn't for echo the fast/slow switch is for attack time on the Noise Gate. Echo is controlled with delay and amount knobs.
Front jack isn't for headphones - it's a mic input jack. I have radios with VOX so I can plug in my headset mic cable into there and earphones RX into the radio and then I can talk using a boom mike headset and run my audio through the ur6qw.
Very cool for hands free operation!![]()
Nice! Will you be selling these? Might be neat to put one inside a base radio.
That would be perfect to run a custom D104 in a big rig.Just made couple to see how it worked in a mobile radio, 10 band eq, SP1A, peak limiter and echo. All bypassed by jumpers but UR6QW EQ is straight off the datasheets, his echo is also straight off some datasheets. Waiting on some parts to assemble.
After playing with a few electret handmics, the frequency response looks promisingThat would be perfect to run a custom D104 in a big rig.
https://www.worldwidedx.com/threads/i-got-bored.259687/#post-740214
Can you record the audio similar to your W2IHY 8 Band review, where the receive radio was near the bench.I’m going to be testing the digital model shortly. Going to try dynamic and condenser mics via the XLR as well. Should be interesting.
