Tightening head on Turner Super Sidekick
Big Kahuna
Jul 31, 2008
1,166
2,164
273
Hey everyone, I'm trying to get chrome cap cover off the back to tighten the head on a Turner Super Sidekick - is it the same as the Turner +3 to get at that screw?
I'm owned tons of +3's but never had a super sidekick with the chrome head so wasn't sure if it was the same. Old posts on here say it is but for the life of me with my thinnest blade I can't get underneath it and it's just damaging it at this point.
Cool, yeah I'll try some heat, I've never had one this crazy to get off, trying not to damage it but the chrome seems softer than the ones on the +3 to get under.
UPDATE - Got it. Took some serious prying, actually snapped the razor blade tip. Some tiny damage to the piece side and a scratch but nothing awful. Head tightened!
Hey guys. I realize how old this thread is, but I have an issue. I've been trying for a couple of days to get that Chrome disc out of there, and I basically scratched it all up when it was in pristine condition. What if I drilled a hole in it and stick a hook in there and pull it out? Cuz it don't seem to be coming out any other way. If I drill a hole am I going to hit something in there? When I put it back in I can cover it with a sticker or something.
You are good. Drill a small hole and pry it off. Just a Philips head screw back there. If you come up with something the fits the spot and looks normal post it up. I have some with no disc. Looked a long time ago but never found anything.
I just realized I've been replying on the wrong thread. Here's where I went after the last post here.
Here's the info post I put on the wrong thread hopefully it will transfer to here.
Okay. Here's some Hardware info.. the screw that holds the mic element housing together is 5/32 8-32 thread by 1 inch. I'm replacing mine cuz the drill bit hit it. I didn't realize the disc was so thin and easy to drill through. I'm going to reuse the disk I have with the hole drilled in it however you can get a 3/16 number 10 washer that's exactly the same size. Once the washer is in I'm going to cover the hole with foil tape. Cut it the same size as the disc . Maybe an exacto knife would be best . They use it in heat and air applications, it can be bought at any hardware store. I happen to have some so I don't need to buy the roll. It's very Chrome looking. You can also use some googly eyes or a silver star. LOL
Attachments​
  • stock-photo-adhesive-aluminum-foil-tape-for-padding-on-white-background-1460216081.jpg
Attachments​
I'm still interested in your elements if they're good.
It will be a couple weeks still. I also have to get a cable made first to go to an RJ45 plug. Someone just dropped off an RCA 40 channel radio yesterday I have to repair as well before I get back to the Turner. I'll keep updating though and let you know. I'm probably going to start a new thread soon. I'm looking for a good emblem plate for the Turner sidekick 100.
