In regard to re-ordering boards, I can't count how many engineers I know, that have been down that road, too many times, so don't feel bad about it.Got this thing putting out a nice waveform. At 9.2v, the LDO hovers at about 120 degrees F.
I had to reorder boards again because AI had me believing pin 37 was updi when it was really 41. So i fixed that and added I2C pullups and the third round of boards is now in production. This voltage controlled output idea worked sweet.
With a board sloppily fixed (pin 41 rerouted), I set it to 15MHz with 9.2v going in, I get this with a 1x probe:
and with 3.6v going in:
Voltage control seems to work good for setting output level. Hopefully this is the last round of ordering boards now. I have mastered every screw up possible along this journey but I finally have a decent signal coming out. I will use this bodged together board to work on code while the new boards are being stamped out.
When you are all done, you need to measure phase noise.
Have fun!
SL
