BinaryRock
Got this thing putting out a nice waveform. At 9.2v, the LDO hovers at about 120 degrees F.
I had to reorder boards again because AI had me believing pin 37 was updi when it was really 41. So i fixed that and added I2C pullups and the third round of boards is now in production. This voltage controlled output idea worked sweet.
With a board sloppily fixed (pin 41 rerouted), I set it to 15MHz with 9.2v going in, I get this with a 1x probe:
and with 3.6v going in:
Voltage control seems to work good for setting output level. Hopefully this is the last round of ordering boards now. I have mastered every screw up possible along this journey but I finally have a decent signal coming out. I will use this bodged together board to work on code while the new boards are being stamped out.
In regard to re-ordering boards, I can't count how many engineers I know, that have been down that road, too many times, so don't feel bad about it.
When you are all done, you need to measure phase noise.
Have fun!
SL
Have fun!
SL
Yep, I fully intend to. My first adventure with the 5351 was an adafruit board. Perhaps the amazon store I bought it from was pretending to be adafruit, but that 5351 was 100% counterfeit. It did output a signal, but the phase noise was TERRIBLE. With the scope triggering on it, it wouldnt sit still. I ordered two 5351's from mouser and swapped it. It was stable after that. Even the markings were obviously lasered off and reprinted.
All mine are direct from mouser so they should be ok but I will check anyhow.
I have a bunch of 5351's, only one is adafruit. I have put my DDS projects on the back burner, probably till winter. I probably have some fakes too. I need to look at them more closely.
Not sure my gear is good enough to get a real measurement. The datasheet on my analyzer says < -98 dBc/Hz @ 1 GHz, 10 kHz offset, but I know it should be better than that at HF. Whether that's good enough or not, I have no clue. I've never done a legit phase noise measurement before and I have no clue what to expect from this 5351. May have to measure the SA's phase noise first, IDK.
@SuperLid
I connected a rubidium standard to the SA reference input and connected the reference output to the front input hoping that the rubidium source had a better phase noise than the SA in hopes to get an idea what the phase noise of the SA is.
I got this, 85.85dB down at +100Hz offset with RBW at 1Hz:
I then programmed the 5351 to output 10MHz and measured that. Since I did not calibrate the frequency yet, I simply offset the second marker by the same 100Hz and ran the averaging again. This time it showed 88.43dB. Somehow it is better than the rubidium source even though the rubidium was still being used as the reference.
Not sure how to interpret that, but if I adjust the voltage on the binaryrock board, the carrier peak and the second marker (and the entire noise floor) move in sync.
I don't know if the phase noise of the SA is limiting the measurement, but I am going to call this good enough. I did notice that the SMA on the rubidium was a tad loose when I took it all apart though, so maybe that should have been tightened better.
@nomadradio
You'll be getting your speed-sensing encoder option.
I ended up paying for grok and I am glad I did. I preloaded it with a ton of details and it output a pretty impressive code. This thing will allow analog and encoder clarifiers (pad 32 selects which), and the clarifier range will be set with pads 30 and 31 (5kHz, 2.5kHz, 1kHz or 500Hz clarifier range on both analog and encoder side). It also has a min, max and center voltage entry for mapping the analog clarifier. The encoder will have three speeds, 1Hz, 10Hz and 100Hz based on rotation speed (push to center). The sketch also determines the optimal settings for the synth based on the soldered frequency so hopefully there will be no pll resets using the clarifier. Since grok is hammering out working codes with every idea I feed it, I might have to ask it about FM too.
This is where I am at so far.
Unfortunately, I am short a few ground connections. Gonna have to splice ground in somewhere for encoder and band switches. Or solder em to the sma pads. Sorry. I do not recommend an SMA connector, should have did header holes to avoid unnecessary load capacitance from coax.
