Sorry,misread the post. Will re read through them again. If the 1ft coax jumper is showing the VSWR flat at where it'a supposed to be, but is the impedance at 50ohms? If not the you will get different readings using your 50ft coax. This is why I suggested adding a 9ft or even a 10ft coax jumper to the existing 50ft. Give this a try and see what you get as 60ft is closer to an electrical 1/2 wave tuned coax jumper for 27.400 or so.
Sorry I misread the post, but I see you edited and I got it now.
Like I said, give the longer coax jumper a try at the radio end of the coax. Post up results using a 9-10ft coax jumper if possible. Curious what you will see. I would also connect a dummy load to the end of the 1ft coax jumper and your mfj meter and set it to said freq where antenna tuned and see what you get for readings and use this as a base line for your future tuning. Make sense?? Hopefully so.
