Spring Contest 2019 CB Contest Rules
binrat
WDX Club Coordinator
Staff member
I Support WorldwideDX.com!
Nov 5, 2008
2,635
1,570
173
The Great White north
Okay gang, Spring 2019 rules. Any questions, please post up. For the Ham rules please look at this thread.
https://www.worldwidedx.com/threads/spring-2019-contests-rules.242651/
  • Only contacts with other WDX members count in the contest. The roster may be found as a sticky thread located http://www.worldwidedx.com/threads/wdx-roster-11-30-2014.28909/
  • Channels: 20-29 AM, 16, 30-39 LSB
  • Date/Time: 0001 25 May – 2359 27 May 2019 UTC. If you're not sure how UTC time works, check herehttp://www.timeanddate.com/worldclock/converter.html?p1=3875
  • Logs must be posted in the WDX Club Contest Contacts forum by the end of contest. Create only one thread for your contacts. You can edit or reply to your own thread, using it as your log throughout the contest. The format is attached as an Excel file. It may be an excel attachment OR pasted into your thread. At the end of the contest, the contacts forum will be locked, so make sure you upload all of your contacts before the end date/time.
  • There is a 2x multiplier for mobile, portable, or maritime contacts. If you operate as mobile, maritime, or portable during the contest, you are credited with the multiplier for any contacts you make. If you operate as a base, you receive a multiplier for any contact you make with a mobile, portable, or maritime contact. 3x multiplier for any contacts outside of CONUS and Canada. Make sure you clearly designate these in your log
  • No amplifiers allowed, CB legal limit.
  • Contacts will be verified against each others' logs
  • This is an "on your honor" contest and intended to be fun. Please play by the rule.
  • BE A COURTEOUS OPERATOR, PROMOTE THE SITE, AND MOST IMPORTANTLY HAVE FUN!
Binrat:
Any problem with including LSB 16? I ask because several of us have been kicking around the idea of trying to bring LSB 16 back to life - in part to relieve the LSB 38 congestion. This contest window might help that cause.
I'll have my Cherokee AH 100 on my boat, where my 1/2 wave Workman Bandit will be on the bow of my 19' open fisherman atop my MFJ 1918 portable tripod. It should make for an interesting week-end.
Binrat:
Changed it for you. I suggest you post in the DXChat box where you are.
Im not sure how to log the entries . What info and in what order do we provide? Could we use the roster spreadsheet ?
