Uniden 980 and RM KL203
Going to try my Galaxy stock mic too on this tomorrow since 980 has talkback. The chrome on the factory mic stands out and in the neighborhood I'm in I'd rather not have shiny in car/truck. May move the 203 up under the radio with zip ties too and off the hump where it kinda laying in the open.
i mod those mics n they work just fine.easy to do too
Reactions: 357magnum
20200309_060224.jpg 20200220_132751.jpg kenworth is stingy in the radio compartment. Wanted to put my galaxy 99v in but even with a 90 degree mic adapter its too big to fit in that little cubby hole.
Wonder if kw n uniden are in kahoots?
My amp was prior in the truck. Never above 1.3 with amp on. Will check tomorrow too.
Took night photo
What do you mean by you Mod the mics?? The factory Uniden or the Galaxy ones?
My Galaxy mic looks like a Workman 507-4 with Ranger stamped in back plastic.
Reactions: Rwb and S&W357
View attachment 35146 View attachment 35147 kenworth is stingy in the radio compartment. Wanted to put my galaxy 99v in but even with a 90 degree mic adapter its too big to fit in that little cubby hole.
I’ve bought the replacement factory part as a spare in a 367 Pete and another truck . Then cut out the original to fit the radio the way I want.
When I get out of that truck I fit the new piece into place. Like nothing ever happened.
It’s how I ran my 99v2 in the oilfield.
Or a
Tac Comm TRC-1
Radio Field Case
Radio & Amp inside case, and a
West Mountain Radio ClearSpeaker
Underneath.
Have a look at the TALL swivel HAM radio bracket at BELLS CB.
(There are also mounts that go on trans tunnel. See also CLAYS CB).
If dimensions work, make it easy to R&R. Remove gear as is convenient (Hide).
Or, throw your nasty-looking safety gear over it when out of truck.
Reactions: Rwb
Take m9c apart.it has a round bandaid looking thing stuck on,remove n toss.then under it is a VERY small hole.carefully drill that hole out little bit at a time,test n redrill.seems like i quit at 3/16",brought modulation up loud n proud
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
