Is that perspective or camera trickery, or is that amp really that small?
i mod those mics n they work just fine.easy to do tooGoing to try my Galaxy stock mic too on this tomorrow since 980 has talkback. The chrome on the factory mic stands out and in the neighborhood I'm in I'd rather not have shiny in car/truck. May move the 203 up under the radio with zip ties too and off the hump where it kinda laying in the open.
My amp was prior in the truck. Never above 1.3 with amp on. Will check tomorrow too.
Took night photo
View attachment 35146 View attachment 35147 kenworth is stingy in the radio compartment. Wanted to put my galaxy 99v in but even with a 90 degree mic adapter its too big to fit in that little cubby hole.
Wonder if kw n uniden are in kahoots?
Get another radio bracket and put it under the radio to mount the amp to.
i measured the 980 it's like 7 1/4" wide. The Cobra 29 says 7 1/4" and some bracket say 7 1/2" for the C29, so I am confused.
looking at C-529 bracket.
I use thin rubber washers as spacers between bracket & radio. Cabinet hardware section or specialty fasteners and washers at HD.
Take m9c apart.it has a round bandaid looking thing stuck on,remove n toss.then under it is a VERY small hole.carefully drill that hole out little bit at a time,test n redrill.seems like i quit at 3/16",brought modulation up loud n proudWhat do you mean by you Mod the mics?? The factory Uniden or the Galaxy ones?
My Galaxy mic looks like a Workman 507-4 with Ranger stamped in back plastic.
